주요 콘텐츠로 건너뛰기
How to Repair a Sole Delamination From the Midsole
필요한 것
  1. How to Repair a Sole Delamination From the Midsole, Check the damaged area: 1 단계, 이미지 1/2 How to Repair a Sole Delamination From the Midsole, Check the damaged area: 1 단계, 이미지 2/2
    • Identify the part of the midsole that needs to be repaired.
  2. How to Repair a Sole Delamination From the Midsole, Remove glue residue: 2 단계, 이미지 1/2 How to Repair a Sole Delamination From the Midsole, Remove glue residue: 2 단계, 이미지 2/2
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material below the midsole.
  3. How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: 3 단계, 이미지 1/3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: 3 단계, 이미지 2/3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: 3 단계, 이미지 3/3
    • Apply the glue to both the sole and the separated part.
    • Apply pressure using clamps.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we left the product to dry overnight.
  4. How to Repair a Sole Delamination From the Midsole, Finished and ready!: 4 단계, 이미지 1/1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
회원 가입일: 07/19/23
5,208 평판
안내서 46개 작성하였습니다
INTERSPORT INTERSPORT 회원
Community
16 회원들
안내서 48개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 56
