주요 콘텐츠로 건너뛰기
How to Repair an Upper Delamination
필요한 것
  1. How to Repair an Upper Delamination, Check the damaged area: 1 단계, 이미지 1/3 How to Repair an Upper Delamination, Check the damaged area: 1 단계, 이미지 2/3 How to Repair an Upper Delamination, Check the damaged area: 1 단계, 이미지 3/3
    • Identify the upper part that needs to be repaired
    • For better pressing later, remove the insole.
  2. How to Repair an Upper Delamination, Remove glue residue: 2 단계, 이미지 1/3 How to Repair an Upper Delamination, Remove glue residue: 2 단계, 이미지 2/3 How to Repair an Upper Delamination, Remove glue residue: 2 단계, 이미지 3/3
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material above the glued sole edge.
  3. How to Repair an Upper Delamination, Prepare the glue: 3 단계, 이미지 1/3 How to Repair an Upper Delamination, Prepare the glue: 3 단계, 이미지 2/3 How to Repair an Upper Delamination, Prepare the glue: 3 단계, 이미지 3/3
    • Follow the instructions of the 2-component glue.
    • Push-out both components of the glue into a small tray and mix the mass until it is equally merged.
  4. How to Repair an Upper Delamination, Coat upper and sole with glue: 4 단계, 이미지 1/3 How to Repair an Upper Delamination, Coat upper and sole with glue: 4 단계, 이미지 2/3 How to Repair an Upper Delamination, Coat upper and sole with glue: 4 단계, 이미지 3/3
    • Using a small spatula, coat the prepared upper surface with the glue.
    • Note: We recommend to get support by another person to pull apart the sole from the upper.
    • Spread the glue equally onto the roughened area and the inside of the sole edge.
  5. How to Repair an Upper Delamination, Pressing both parts together: 5 단계, 이미지 1/3 How to Repair an Upper Delamination, Pressing both parts together: 5 단계, 이미지 2/3 How to Repair an Upper Delamination, Pressing both parts together: 5 단계, 이미지 3/3
    • Let the glue dry while putting one hand into the shoe and grasping the sole with the other one.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we held the parts together for 3 minutes and then let it dry for 24 hours.
  6. How to Repair an Upper Delamination, Finished and ready!: 6 단계, 이미지 1/3 How to Repair an Upper Delamination, Finished and ready!: 6 단계, 이미지 2/3 How to Repair an Upper Delamination, Finished and ready!: 6 단계, 이미지 3/3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
회원 가입일: 07/19/23
5,208 평판
안내서 46개 작성하였습니다
INTERSPORT INTERSPORT 회원
Community
16 회원들
안내서 48개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 42
