주요 콘텐츠로 건너뛰기
How to Repair a Squareplug Patch Cable with SP400 Plugs
필요한 것
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: 1 단계, 이미지 1개 중 1개
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: 2 단계, 이미지 1개 중 1개
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: 3 단계, 이미지 3개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 3 단계, 이미지 3개 중 2개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 3 단계, 이미지 3개 중 3개
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: 4 단계, 이미지 2개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 4 단계, 이미지 2개 중 2개
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: 5 단계, 이미지 3개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 5 단계, 이미지 3개 중 2개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 5 단계, 이미지 3개 중 3개
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: 6 단계, 이미지 3개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 6 단계, 이미지 3개 중 2개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 6 단계, 이미지 3개 중 3개
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: 7 단계, 이미지 3개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 7 단계, 이미지 3개 중 2개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 7 단계, 이미지 3개 중 3개
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: 8 단계, 이미지 2개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 8 단계, 이미지 2개 중 2개
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: 9 단계, 이미지 1개 중 1개
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: 10 단계, 이미지 2개 중 1개 How to Repair a Squareplug Patch Cable with SP400 Plugs: 10 단계, 이미지 2개 중 2개
    • Verify that the cable is working (responsive yellow and green LED indicators).
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Crystal Edwards
회원 가입일: 09/21/18
450 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 885
