주요 콘텐츠로 건너뛰기
How to Repair a Torn Seam in your Patagonia Clothing
필요한 것
  1. How to Repair a Torn Seam in your Patagonia Clothing, How to Repair a Torn Seam in your Patagonia Clothing: 1 단계, 이미지 1/2 How to Repair a Torn Seam in your Patagonia Clothing, How to Repair a Torn Seam in your Patagonia Clothing: 1 단계, 이미지 2/2
    • Examine the damaged seam in your garment, checking for tears and removing any loose threads.
  2. How to Repair a Torn Seam in your Patagonia Clothing: 2 단계, 이미지 1/3 How to Repair a Torn Seam in your Patagonia Clothing: 2 단계, 이미지 2/3 How to Repair a Torn Seam in your Patagonia Clothing: 2 단계, 이미지 3/3
    • Flatten out the garment around the torn seam, and align the fabric where the seam used to be.
    • Pin the two layers together. Be sure to catch only the two layers of fabric you wish to sew back together.
  3. How to Repair a Torn Seam in your Patagonia Clothing: 3 단계, 이미지 1/3 How to Repair a Torn Seam in your Patagonia Clothing: 3 단계, 이미지 2/3 How to Repair a Torn Seam in your Patagonia Clothing: 3 단계, 이미지 3/3
    • Open the garment as much as possible, laying the seam flat.
    • Check your alignment and make sure the two edges of your fabric line up.
    • Put the garment in the machine, starting a few inches before the torn seam to overlap with the stitches.
    • Drop the presser foot. Align the first line of stitches with the needle.
  4. How to Repair a Torn Seam in your Patagonia Clothing: 4 단계, 이미지 1/2 How to Repair a Torn Seam in your Patagonia Clothing: 4 단계, 이미지 2/2
    • Use the balance wheel to sink the needle into the fabric.
    • Only turn the balance wheel in the direction that advances the machine. Turning the wheel the opposite direction can cause tangling or ruin the tension on the machine.
  5. How to Repair a Torn Seam in your Patagonia Clothing: 5 단계, 이미지 1/2 How to Repair a Torn Seam in your Patagonia Clothing: 5 단계, 이미지 2/2
    • Sew along the first line of stitches, removing the pins before you get to them.
    • If you run over the pins, you risk breaking your needle.
  6. How to Repair a Torn Seam in your Patagonia Clothing: 6 단계, 이미지 1/2 How to Repair a Torn Seam in your Patagonia Clothing: 6 단계, 이미지 2/2
    • When you come to the end of the row of stitches, engage the backstitch function of your machine. Backstitching prevents the seam from unraveling.
    • Backstitch functions vary widely between machines and can come in the form of buttons, levers, and knobs. See your sewing machine manual for instructions on your backstitch function.
    • Depress the pedal slowly. Sew two or three stitches backwards. Release the pedal and disengage the backstitch function.
  7. How to Repair a Torn Seam in your Patagonia Clothing: 7 단계, 이미지 1/2 How to Repair a Torn Seam in your Patagonia Clothing: 7 단계, 이미지 2/2
    • After you've completely sewn over the torn seam, clip the threads and free the garment from the machine.
  8. How to Repair a Torn Seam in your Patagonia Clothing: 8 단계, 이미지 1/3 How to Repair a Torn Seam in your Patagonia Clothing: 8 단계, 이미지 2/3 How to Repair a Torn Seam in your Patagonia Clothing: 8 단계, 이미지 3/3
    • Some clothes have two rows of stitching, If your garment does, reposition it in the sewing machine. Drop the needle into the second line of stitches at about where you began sewing your previous seam.
    • Repeat steps 3-7 of this guide to resew the second line of stitches.
    • You do not need to pin this seam, because the first seam will hold the garment in place.
    • If your garment only has a single line of stitches, skip this step and proceed to the next step.
  9. How to Repair a Torn Seam in your Patagonia Clothing: 9 단계, 이미지 1/1
    • Check that your stitches are straight and secure.
    • Admire your work.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,113 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 한 개
You will want to put the pins in (if possible to catch all layers) perpendicular to the seam you are sewing. Then you can sew right over them without breaking your needle. Plus you will not poke yourself as they come at you in the line of travel!
AMY - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 56
전체 시간: 7,462
