주요 콘텐츠로 건너뛰기
How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery
필요한 것
  1. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 1 단계, 이미지 1/3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 1 단계, 이미지 2/3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 1 단계, 이미지 3/3
    • Set your gel blaster flat on a table.
    • Push the battery compartment release tab upwards.
    • Lift the battery cover and remove it.
  2. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 2 단계, 이미지 1/3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 2 단계, 이미지 2/3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 2 단계, 이미지 3/3
    • Squeeze both the left and the right side of the release latch and pull apart the connector to remove the battery from the gel blaster's motor.
  3. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 3 단계, 이미지 1/1
    • Remove the battery from the battery compartment.
  4. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 4 단계, 이미지 1/2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 4 단계, 이미지 2/2
    • Use utility scissors to cut the first green layer of the battery.
    • Remove the first layer to expose the connection to the wire.
    • Be careful when cutting the top layer, and do not remove the inner plastic layer.
  5. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 5 단계, 이미지 1/2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 5 단계, 이미지 2/2
    • Using the soldering iron and the lead-free solder, re-solder the wire to the battery to ensure a stable connection.
    • If there is any confusion on how to solder, please refer to the link below: How To Solder and Desolder Connections
  6. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 6 단계, 이미지 1/2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 6 단계, 이미지 2/2
    • Insert the battery back into the battery compartment.
    • Reconnect the battery to the motor.
    • Replace the cover to close the battery compartment.
결론
Bryan Mendoza
회원 가입일: 02/10/23
145 평판
안내서 1개 작성함
University of Memphis, Team 3-3, Sneed Spring 2024 University of Memphis, Team 3-3, Sneed Spring 2024 회원
UM-SNEED-S24S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 74
전체 시간: 798
