주요 콘텐츠로 건너뛰기
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
필요한 것
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 1 단계, 이미지 1/1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 2 단계, 이미지 1/2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 2 단계, 이미지 2/2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 3 단계, 이미지 1/1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 4 단계, 이미지 1/1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 5 단계, 이미지 1/1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 6 단계, 이미지 1/1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 7 단계, 이미지 1/1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 8 단계, 이미지 1/2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 8 단계, 이미지 2/2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 9 단계, 이미지 1/1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 10 단계, 이미지 1/1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 11 단계, 이미지 1/1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 12 단계, 이미지 1/1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 13 단계, 이미지 1/1
    • You are now finished!
결승점
John Hiller
회원 가입일: 10/05/15
110 평판
안내서 1개 작성함
Colorado Springs, Team 7-5, Mcmichael Fall 2015 Colorado Springs, Team 7-5, Mcmichael Fall 2015 회원
UCCS-MCMICHAEL-F15S7G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 1,820
