주요 콘텐츠로 건너뛰기
How to Replace Hot and Cold Water Pipes for a Washer
필요한 것
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: 1 단계, 이미지 1개 중 1개
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 2 단계, 이미지 3개 중 1개 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 2 단계, 이미지 3개 중 2개 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 2 단계, 이미지 3개 중 3개
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: 3 단계, 이미지 1개 중 1개
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: 4 단계, 이미지 1개 중 1개
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: 5 단계, 이미지 1개 중 1개
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 6 단계, 이미지 3개 중 1개 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 6 단계, 이미지 3개 중 2개 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 6 단계, 이미지 3개 중 3개
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 7 단계, 이미지 2개 중 1개 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 7 단계, 이미지 2개 중 2개
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
결론
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jenish
회원 가입일: 01/22/21
169 평판
안내서 1개를 작성함
1가이드 댓글
Those are hoses. Pipes are in the wall
NitWit - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 34
지난 30일: 125
전체 시간: 9,960
