주요 콘텐츠로 건너뛰기
How to Replace Your iPhone 16 Pro Rear Glass Adhesive
필요한 것
  1. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Remove the leftover adhesive: 1 단계, 이미지 3개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Remove the leftover adhesive: 1 단계, 이미지 3개 중 2개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Remove the leftover adhesive: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
  2. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Clean the back glass: 2 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Clean the back glass: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
  3. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Clean the frame: 3 단계, 이미지 1개 중 1개
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
  4. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Apply the replacement adhesive: 4 단계, 이미지 1개 중 1개
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
  5. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 5 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 5 단계, 이미지 2개 중 2개
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
  6. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 6 단계, 이미지 3개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 6 단계, 이미지 3개 중 2개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 6 단계, 이미지 3개 중 3개
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
  7. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 7 단계, 이미지 3개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 7 단계, 이미지 3개 중 2개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 7 단계, 이미지 3개 중 3개
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
  8. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 8 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 8 단계, 이미지 2개 중 2개
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
  9. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 9 단계, 이미지 3개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 9 단계, 이미지 3개 중 2개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 9 단계, 이미지 3개 중 3개
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
  10. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Connect the back glass: 10 단계, 이미지 1개 중 1개
    • Prop up the back glass along the right edge of your iPhone.
  11. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 11 단계, 이미지 1개 중 1개
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
  12. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Connect the battery: 12 단계, 이미지 1개 중 1개
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
  13. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Install the connector covers: 13 단계, 이미지 1개 중 1개
    • Align the back glass connector cover by its screw holes and lay it in place.
  14. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 14 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
    • Two 1.3 mm‑long screws
    • Two 1.0 mm‑long screws
  15. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 15 단계, 이미지 1개 중 1개
    • Align the battery connector cover by its screw holes and lay it in place.
  16. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 16 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
    • One 1.0 mm‑long screw
  17. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Remove the final adhesive liners: 17 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Remove the final adhesive liners: 17 단계, 이미지 2개 중 2개
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
  18. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 18 단계, 이미지 3개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 18 단계, 이미지 3개 중 2개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 18 단계, 이미지 3개 중 3개
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
  19. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Apply heat to the perimeter: 19 단계, 이미지 1개 중 1개
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
  20. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Apply pressure to the perimeter: 20 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Apply pressure to the perimeter: 20 단계, 이미지 2개 중 2개
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
  21. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 21 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 21 단계, 이미지 2개 중 2개
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
  22. How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 22 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive: 22 단계, 이미지 2개 중 2개
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
  23. How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Install the pentalobe screws: 23 단계, 이미지 2개 중 1개 How to Replace Your iPhone 16 Pro Rear Glass Adhesive, Install the pentalobe screws: 23 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
결론
Congratulations, your new adhesive is good to go!
Nick Schultz
회원 가입일: 03/24/24
37,787 평판
안내서 226개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
very great photography
Kyeler W - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 27
지난 30일: 132
전체 시간: 2,072
