주요 콘텐츠로 건너뛰기
How to Replace a Plastic Snap With a Handheld Tool
필요한 것
  1. How to Replace a Plastic Snap With a Handheld Tool, Snap information: 1 단계, 이미지 2개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Snap information: 1 단계, 이미지 2개 중 2개
    • A full set of plastic snaps consists of four parts:
    • Two caps
    • One stud
    • One socket
    • When the snap is installed, the socket and stud will lock together, while a cap holds each of them in place from the other side of the fabric.
  2. How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: 2 단계, 이미지 3개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: 2 단계, 이미지 3개 중 2개 How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: 2 단계, 이미지 3개 중 3개
    • Follow this step if you need to remove an existing plastic snap.
    • Use pliers to crush the plastic snap until it loosens from the fabric.
    • Remove and discard the broken plastic snap pieces.
    • You can't reuse plastic snaps even if they look undamaged.
  3. How to Replace a Plastic Snap With a Handheld Tool, Clear the fabric hole: 3 단계, 이미지 2개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Clear the fabric hole: 3 단계, 이미지 2개 중 2개
    • Push the point of an awl through the fabric hole to clear it for the cap.
  4. How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: 4 단계, 이미지 3개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: 4 단계, 이미지 3개 중 2개 How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: 4 단계, 이미지 3개 중 3개
    • Use your fingers to squeeze a cap pin through the fabric hole.
  5. How to Replace a Plastic Snap With a Handheld Tool: 5 단계, 이미지 3개 중 1개 How to Replace a Plastic Snap With a Handheld Tool: 5 단계, 이미지 3개 중 2개 How to Replace a Plastic Snap With a Handheld Tool: 5 단계, 이미지 3개 중 3개
    • Place either a stud or a socket on top of the pin.
    • If you can't see the pin after placing the stud or socket, the fabric is too thick for the snap. You'll need a cap with a longer pin.
  6. How to Replace a Plastic Snap With a Handheld Tool: 6 단계, 이미지 2개 중 1개 How to Replace a Plastic Snap With a Handheld Tool: 6 단계, 이미지 2개 중 2개
    • Make sure the snap is facing the correct side for the clothing item.
    • Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
  7. How to Replace a Plastic Snap With a Handheld Tool: 7 단계, 이미지 3개 중 1개 How to Replace a Plastic Snap With a Handheld Tool: 7 단계, 이미지 3개 중 2개 How to Replace a Plastic Snap With a Handheld Tool: 7 단계, 이미지 3개 중 3개
    • Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
    • Release the handles and remove the tool from the snap.
  8. How to Replace a Plastic Snap With a Handheld Tool, Check the new snap: 8 단계, 이미지 2개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Check the new snap: 8 단계, 이미지 2개 중 2개
    • Visually inspect the snap. The center pin should be evenly flattened.
    • Pull on the snap. The snap shouldn't feel loose.
    • If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
  9. How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: 9 단계, 이미지 3개 중 1개 How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: 9 단계, 이미지 3개 중 2개 How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: 9 단계, 이미지 3개 중 3개
    • Repeat the procedure to install the other half of the snap set.
결론
For more clothing repair guides, click here.
작성자
3다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
313,818 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 114
지난 30일: 473
전체 시간: 2,291
