주요 콘텐츠로 건너뛰기
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
필요한 것
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 1 단계, 이미지 2개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 1 단계, 이미지 2개 중 2개
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 2 단계, 이미지 3개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 2 단계, 이미지 3개 중 2개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 2 단계, 이미지 3개 중 3개
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 3 단계, 이미지 2개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 3 단계, 이미지 2개 중 2개
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 4 단계, 이미지 3개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 4 단계, 이미지 3개 중 2개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 4 단계, 이미지 3개 중 3개
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 5 단계, 이미지 1개 중 1개
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 6 단계, 이미지 3개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 6 단계, 이미지 3개 중 2개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 6 단계, 이미지 3개 중 3개
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 7 단계, 이미지 2개 중 1개 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 7 단계, 이미지 2개 중 2개
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 8 단계, 이미지 1개 중 1개
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 9 단계, 이미지 1개 중 1개
    • Solder the new speaker to the wires taken off in step 5.
결론
To reassemble your device, follow these instructions in reverse order from step 3.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mikey
회원 가입일: 03/23/20
229 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 21
전체 시간: 752
