주요 콘텐츠로 건너뛰기
How to Replace the Back Cover Adhesive (Back Cover First)
필요한 것
  1. How to Replace the Back Cover Adhesive (Back Cover First), Remove the remaining adhesive: 1 단계, 이미지 1개 중 1개
    • If you're re-using your back cover, remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • Repeat the same procedure for any remaining adhesive on the frame.
  2. How to Replace the Back Cover Adhesive (Back Cover First): 2 단계, 이미지 1개 중 1개
    • Before removing any liners, position the adhesive strip with the clear liner facing down over the back cover to find the proper orientation.
    • You can use the rear camera cutout as a reference point.
    • If the adhesive matches the frame instead of the back cover, follow this frame-first adhesive guide.
  3. How to Replace the Back Cover Adhesive (Back Cover First), Expose the adhesive: 3 단계, 이미지 2개 중 1개 How to Replace the Back Cover Adhesive (Back Cover First), Expose the adhesive: 3 단계, 이미지 2개 중 2개
    • Peel the clear liner off of the adhesive strip to expose the adhesive.
  4. How to Replace the Back Cover Adhesive (Back Cover First), Align the adhesive: 4 단계, 이미지 3개 중 1개 How to Replace the Back Cover Adhesive (Back Cover First), Align the adhesive: 4 단계, 이미지 3개 중 2개 How to Replace the Back Cover Adhesive (Back Cover First), Align the adhesive: 4 단계, 이미지 3개 중 3개
    • Be very careful with this step, as misaligning the adhesive can cause it to peek out of the phone during reassembly, leading to an improper seal.
    • The adhesive is very sticky! Be careful with alignment, as you won't be able to reposition the adhesive once it sticks.
    • Carefully align the sticky side of the adhesive over the edges of the back cover.
    • You can use the corners of the back cover to help line up the edges.
    • Press down on the perimeter of the adhesive strip to bond it to the back cover.
  5. How to Replace the Back Cover Adhesive (Back Cover First): 5 단계, 이미지 2개 중 1개 How to Replace the Back Cover Adhesive (Back Cover First): 5 단계, 이미지 2개 중 2개
    • Peel off the colored liner from the adhesive strip to expose the opposite side of the adhesive.
  6. How to Replace the Back Cover Adhesive (Back Cover First), Replace the microphone adhesive: 6 단계, 이미지 3개 중 1개 How to Replace the Back Cover Adhesive (Back Cover First), Replace the microphone adhesive: 6 단계, 이미지 3개 중 2개 How to Replace the Back Cover Adhesive (Back Cover First), Replace the microphone adhesive: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • This step shows how to install a replacement microphone gasket. If your kit didn't come with this gasket, skip this step.
    • Use tweezers to remove the old microphone gasket. It may be attached to the back cover or the phone.
    • Remove the clear liner from the large L-shaped adhesive piece.
    • Place the square piece of adhesive over the back cover's microphone cutout under the flash unit, with the blue liner tab facing right.
    • Remove the blue liner.
  7. How to Replace the Back Cover Adhesive (Back Cover First): 7 단계, 이미지 2개 중 1개 How to Replace the Back Cover Adhesive (Back Cover First): 7 단계, 이미지 2개 중 2개
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Align the back cover with its original position on the frame.
    • Press down on the perimeter of the adhesive to bond the adhesive to the frame.
    • To ensure a good seal, apply constant pressure to the back cover with a flat, heavy object. A hefty book works well.
    • If a substantial gap remains, try squeezing the gap with your fingers but don't force it. Pry the back cover off and check for any surface irregularities, such as unseated connectors or loose and jutting screws.
결승점
다른 26명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,813 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,611개를 작성함
3가이드 댓글
Where can I get the genuine adhesive for Galaxy S22 Ultra??
Will Dennis - 답글
There's a link at the beginning of the instructions.
Shell -
What can I do with my old battery (and daughter board)?
Nick Boreham - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 137
지난 30일: 754
전체 시간: 19,581
