소개
Use this guide to replace the back cover adhesive by applying it to the frame first.
To determine where you first apply the adhesive, match the contours of the adhesive on the clear side with the back cover and the frame. If your adhesive strip matches the bottom cover, follow this guide instead.
The frame-first adhesive tends to have screw holes in the colored lining.
This guide is applicable for all Galaxy S20 devices.
필요한 것
If you're re-using your frame, remove the remaining adhesive.
Repeat the same procedure for any remaining adhesive on the back cover.
Before removing any liners, position the adhesive strip with the clear liner facing down over the frame to find the proper orientation.
If the adhesive matches the back cover instead of the frame, follow this cover-first adhesive guide.
Carefully align the sticky side of the adhesive over the edges of the frame.
Press down on the perimeter of the adhesive strip to bond it to the frame.
다른 6명이 해당 안내서를 완성하였습니다.
