주요 콘텐츠로 건너뛰기
How to Replace the Back Panel Adhesive on Your Google Pixel 4
필요한 것
  1. How to Replace the Back Panel Adhesive on Your Google Pixel 4, Scrape off the old adhesive: 1 단계, 이미지 3개 중 1개 How to Replace the Back Panel Adhesive on Your Google Pixel 4, Scrape off the old adhesive: 1 단계, 이미지 3개 중 2개 How to Replace the Back Panel Adhesive on Your Google Pixel 4, Scrape off the old adhesive: 1 단계, 이미지 3개 중 3개
    • When scraping the frame and back panel, take care not to damage the spring contacts and graphite film.
    • Use the flat end of a spudger or your fingernail to scrape off the old adhesive from the frame and back panel.
  2. How to Replace the Back Panel Adhesive on Your Google Pixel 4, Remove the remaining adhesive: 2 단계, 이미지 2개 중 1개 How to Replace the Back Panel Adhesive on Your Google Pixel 4, Remove the remaining adhesive: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you're still having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Back Panel Adhesive on Your Google Pixel 4, Orient the adhesive: 3 단계, 이미지 1개 중 1개
    • Before peeling off any liners, lay the new adhesive down on the back panel and use the camera cutout to find its proper orientation.
  4. How to Replace the Back Panel Adhesive on Your Google Pixel 4, Remove the adhesive liner: 4 단계, 이미지 1개 중 1개
    • Peel and remove the large rectangular liner.
    • This should expose the adhesive that will stick to the back panel.
  5. How to Replace the Back Panel Adhesive on Your Google Pixel 4, Apply the adhesive: 5 단계, 이미지 3개 중 1개 How to Replace the Back Panel Adhesive on Your Google Pixel 4, Apply the adhesive: 5 단계, 이미지 3개 중 2개 How to Replace the Back Panel Adhesive on Your Google Pixel 4, Apply the adhesive: 5 단계, 이미지 3개 중 3개
    • Be very careful during this step! The adhesive is very sticky, and once it touches the back panel you won't be able to reposition it. Misaligned adhesive can lead to an improper seal.
    • When laying down the adhesive, make sure the back panel connector cable is threaded through the camera cutout. If the adhesive sticks to the cable, you'll have to restart the repair with new adhesive.
    • With the adhesive in its proper orientation, lay it sticky side down on the back panel.
    • Press down firmly around the perimeter of the back panel, ensuring all the adhesive is secured.
  6. How to Replace the Back Panel Adhesive on Your Google Pixel 4: 6 단계, 이미지 2개 중 1개 How to Replace the Back Panel Adhesive on Your Google Pixel 4: 6 단계, 이미지 2개 중 2개
    • Use the pull tabs to remove all remaining liners from the adhesive.
  7. How to Replace the Back Panel Adhesive on Your Google Pixel 4: 7 단계, 이미지 1개 중 1개
    • Return to your phone's repair guide and continue reassembly.
    • Be very careful when reassembling your device, as the adhesive is exposed and very sticky. Take special care to prevent the back panel cable from touching the adhesive.
    • Return to this guide before securing the back panel to the phone.
  8. How to Replace the Back Panel Adhesive on Your Google Pixel 4: 8 단계, 이미지 3개 중 1개 How to Replace the Back Panel Adhesive on Your Google Pixel 4: 8 단계, 이미지 3개 중 2개 How to Replace the Back Panel Adhesive on Your Google Pixel 4: 8 단계, 이미지 3개 중 3개
    • Align the back panel over the back of the phone and lay it down.
    • Secure the back panel by firmly pressing along its perimeter for one minute.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,601 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,625개를 작성함
1가이드 댓글
I used 70 % isopropyl alcohol instead of 90 %, I don't think it was as effective as it should have been though.
I did step 7 before step 6 as I was afraid that it wasn't going to stick as intended. When doing step 7, but the back panel connector did disconnect from the back panel and not from the phone's inside.
Luigi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 75
전체 시간: 3,865
