이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Temple tip is a part that is usually made of plastic or silicon materials. It covers metal parts of eyeglass’s arms. Especially, temple tips help to keep the metal of the frame in place and to make sure that it will not touch the wearer’s skin because the metal part can snap off on the back of the wearer’s ear and cause the feeling of irritation or hurting of skin.
This problem can frequently happen when people have a metal eyeglass with bad quality temple tip material. Therefore, the guide of repairing a temple tip on eyeglasses can help to save time or money instead of bringing it to an optical to fixing.
필요한 것
Put all separated parts of the eyeglass including the eyeglass frame, temple tip on a clean and flat surface.
Fixing a temple tip of eyeglasses is an uncomplicated process that you can do at home by yourself. Our instruction will have some steps, following:
다른 2명이 해당 안내서를 완성하였습니다.
