소개
The following guide will show you how to shorten the straps on a tank top. There is no sewing machine required; instead, you’ll use a needle and thread to sew the strap back in place by hand. This guide is specifically made for tank tops or dresses that have an existing seam at the end of the strap. Here are some sewing resources that may help you:
필요한 것
Put on the top.
Hold and stretch the strap to the desired length.
Secure the desired length of the strap with a safety pin.
Use a needle and a thread that has a similar color to the fabric to sew the strap to the seam of the top.
Pierce the needle through the fabric of the top and then pull the needle through the strap.
Continue the same process downwards until reaching the end of the seam of the top.
Tie a knot after pulling the string.
Cut the excess thread.
Repeat the step for the opposite side of the strap and the upper side of the strap.
