주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Rip a Seam
필요한 것
    1. How to Rip a Seam, How to Rip a Seam: 1 단계, 이미지 2개 중 1개 How to Rip a Seam, How to Rip a Seam: 1 단계, 이미지 2개 중 2개
      • Slip the sharp end of the seam ripper through a single stitch in the seam you want to remove.
      • Be sure your seam ripper goes through only the stitch, not the fabric, or you could puncture/tear the fabric.
      댓글 쓰기
      • Slide the seam ripper forward, bringing the stitch into the crux of the seam ripper's fork and onto the blade.
      • Gently push the seam ripper forward, cutting the thread.
      • Rely on the blade to do the work. Do not apply a lot of force, as the seam ripper can slip and puncture the fabric.
      댓글 쓰기
    2. How to Rip a Seam: 3 단계, 이미지 1개 중 1개
      • You can use the method described in steps 1 and 2 to completely rip any seam. However, if you have a seam that binds two pieces of fabric, it is easier to rip the seam using the method described in step 4, below.
      • In order to use the method in Step 4, you need to remove the first few stitches of the seam using the method we already described in Step 1. Removing these stitches enables you to separate the two pieces of fabric and use the seam ripper on the stitches that hold them together.
      • Using the method below also helps prevent accidental puncturing of the garment.
      댓글 쓰기
    3. How to Rip a Seam: 4 단계, 이미지 2개 중 1개 How to Rip a Seam: 4 단계, 이미지 2개 중 2개
      • Separate the two pieces of fabric held together by your seam.
      • Bring the sharp end of the seam ripper between the two pieces of fabric.
      • Slip the sharp end of the seam ripper beneath one of the stitches. Be careful to avoid catching the fabric.
      댓글 쓰기
      • Slide the seam ripper forward. Bring the thread into the crux of the fork and onto the blade.
      • Gently push the seam ripper forward again, cutting the thread.
      • Continue working, stitch by stitch, until the seam has been removed. Take your time, being careful not to damage the fabric.
      • Remove all of the loose threads from the ripped seam to prevent tangling when you resew the seam.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
91,032 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 71,143개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 33
지난 30일: 138
전체 시간: 27,787
