주요 콘텐츠로 건너뛰기
How to Test Outerwear for Water Repellency
필요한 것
  1. How to Test Outerwear for Water Repellency, How to Test Outerwear for Water Repellency: 1 단계, 이미지 2개 중 1개 How to Test Outerwear for Water Repellency, How to Test Outerwear for Water Repellency: 1 단계, 이미지 2개 중 2개
    • Lay your jacket on a table or flat surface.
    • Spray the jacket with water.
  2. How to Test Outerwear for Water Repellency: 2 단계, 이미지 2개 중 1개 How to Test Outerwear for Water Repellency: 2 단계, 이미지 2개 중 2개
    • Observe the water.
    • If the water sinks in and absorbs into the material, your jacket is "wetting out". The coating can either be "reset" by washing and drying, or by reapplying the coating as shown in this guide.
  3. How to Test Outerwear for Water Repellency: 3 단계, 이미지 3개 중 1개 How to Test Outerwear for Water Repellency: 3 단계, 이미지 3개 중 2개 How to Test Outerwear for Water Repellency: 3 단계, 이미지 3개 중 3개
    • If the water beads up, staying on the outside of the garment like dew drops, your jacket does not need to have the durable water repellent finish reapplied.
    • Water droplets should roll right off of the jacket when you pick it up.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 3,530
