주요 콘텐츠로 건너뛰기
How to Tighten Loose Bike Spokes
필요한 것
  1. How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 1 단계, 이미지 3개 중 1개 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 1 단계, 이미지 3개 중 2개 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 1 단계, 이미지 3개 중 3개
    • Place the bike in a position where you can comfortably access the wheel.
  2. How to Tighten Loose Bike Spokes: 2 단계, 이미지 1개 중 1개
    • Inspect the wheel and look for loose spokes.
  3. How to Tighten Loose Bike Spokes: 3 단계, 이미지 3개 중 1개 How to Tighten Loose Bike Spokes: 3 단계, 이미지 3개 중 2개 How to Tighten Loose Bike Spokes: 3 단계, 이미지 3개 중 3개
    • Use a spoke wrench to tighten the spoke. Retighten the spoke clockwise a quarter turn at a time.
  4. How to Tighten Loose Bike Spokes: 4 단계, 이미지 2개 중 1개 How to Tighten Loose Bike Spokes: 4 단계, 이미지 2개 중 2개
    • Since you just adjusted the tension of a spoke, we need to make sure the tension in all the spokes is equal throughout.
    • Use the spoke wrench to adjust the rest of the spokes as needed so that they all have equal tension. Turn the spoke wrench clockwise a quarter at a time.
  5. How to Tighten Loose Bike Spokes: 5 단계, 이미지 1개 중 1개
    • Once the spokes are tightened, relieve the tension in the spokes by squeezing them.
    • This is to check that your spokes are now secure and won’t get loose.
    • Be sure to give the loose spokes an extra test to make sure they are now sturdy.
  6. How to Tighten Loose Bike Spokes: 6 단계, 이미지 1개 중 1개
    • Spin the wheel to make sure the spokes are secure and to make sure that the wheel does not need additional truing.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Pavle Janev
회원 가입일: 01/12/22
184 평판
안내서 1개를 작성함
댓글 한 개
You should notice the tension spoke when tightening your bike spoke because it will affect the wheel’s stability. Tighten clockwise and turning the wrench in small increments of about a quarter turn will allow you to avoid tightening too much.
Dalton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 48
전체 시간: 6,535
