주요 콘텐츠로 건너뛰기
How to Use the Anti-Static Wrist Strap
필요한 것
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: 1 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap, Remove any jewelry: 1 단계, 이미지 2개 중 2개
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: 2 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap, Adjust the strap: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $7.95
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: 3 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap: 3 단계, 이미지 2개 중 2개
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: 4 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap: 4 단계, 이미지 2개 중 2개
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: 5 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap: 5 단계, 이미지 2개 중 2개
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: 6 단계, 이미지 2개 중 1개 How to Use the Anti-Static Wrist Strap: 6 단계, 이미지 2개 중 2개
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
  7. How to Use the Anti-Static Wrist Strap: 7 단계, 이미지 1개 중 1개
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
결론
For other general electronics skills guides, click here.
다른 49명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,039 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
7가이드 댓글
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - 답글
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - 답글
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Lucka Lellig - 답글
Si vous êtes sûre que votre prise est réellement reliée à la terre (ce n'est souvent pas le cas dans les immeubles anciens, ils peuvent une prise de terre reliée à rien) oui la fiche terre (la fiche qui sort de la prise, surtout pas les trous qui sont la phase et le neutre et qui pourraient vous électrocuter - je précise car la réponse précédente semble confondre) sera parfaite.
Marcanpilami -
댓글 쓰기
조회 통계:
지난 24시간: 39
지난 7일: 247
지난 30일: 1,530
전체 시간: 59,682
