주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Use the Portable Anti-Static Mat
필요한 것
  1. How to Use the Portable Anti-Static Mat, Unfold the mat: 1 단계, 이미지 3개 중 1개 How to Use the Portable Anti-Static Mat, Unfold the mat: 1 단계, 이미지 3개 중 2개 How to Use the Portable Anti-Static Mat, Unfold the mat: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $34.95
    • Unfold your anti-static mat and spread it out on your work area.
    • Make sure the iFixit logo is facing upward.
    댓글 쓰기
  2. How to Use the Portable Anti-Static Mat, Attach the black grounding wire: 2 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat, Attach the black grounding wire: 2 단계, 이미지 2개 중 2개
    • Place the black grounding wire's connector over one of the mat's grounding nodes.
    • Press down on the connector until you hear a click to secure it to the mat.
    댓글 쓰기
  3. How to Use the Portable Anti-Static Mat: 3 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 3 단계, 이미지 2개 중 2개
    • Attach the black grounding wire's clip to a grounded metal surface.
    • To ensure a good grip on the surface, pinch hard on the clip's levers to open the jaws wide.
    댓글 쓰기
  4. How to Use the Portable Anti-Static Mat: 4 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    댓글 쓰기
  5. How to Use the Portable Anti-Static Mat, Adjust the strap: 5 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat, Adjust the strap: 5 단계, 이미지 2개 중 2개
    • The anti-static strap should be adjusted to fit snug on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
    댓글 쓰기
  6. How to Use the Portable Anti-Static Mat: 6 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 6 단계, 이미지 2개 중 2개
    • To tighten the strap, pull the looped end away from the plastic slide.
    댓글 쓰기
  7. How to Use the Portable Anti-Static Mat: 7 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 7 단계, 이미지 2개 중 2개
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
    댓글 쓰기
  8. How to Use the Portable Anti-Static Mat: 8 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 8 단계, 이미지 2개 중 2개
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
    댓글 쓰기
  9. How to Use the Portable Anti-Static Mat, Plug in the strap: 9 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat, Plug in the strap: 9 단계, 이미지 2개 중 2개
    • Disconnect the strap's metal clip from the rest of the blue grounding wire.
    댓글 쓰기
  10. How to Use the Portable Anti-Static Mat: 10 단계, 이미지 2개 중 1개 How to Use the Portable Anti-Static Mat: 10 단계, 이미지 2개 중 2개
    • Insert the tip of the blue grounding wire into one of the black grounding wire's sockets.
    댓글 쓰기
  11. How to Use the Portable Anti-Static Mat: 11 단계, 이미지 1개 중 1개
    • Place your device on the mat.
    • You're now ready for repairs!
    • Throughout the repair, keep the device centered on the mat to minimize ESD.
    댓글 쓰기
결론
For other general electronics skills guides, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 37명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
245,452 평판
안내서 1,203개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 32,107개를 작성함
9가이드 댓글
What else can the mat be grounded to, as I don't have a metal desk.
Cringe_Master245 - 답글 공유
Hi there.
Technically, you can ground yourself to any large, metal object that is touching the ground. If you don't have any in your vicinity, then you can clip the wire to the middle screw in your outlet or plug the wire into the bottom-most ground slot in the outlet.
Alex Diaz-Kokaisl - 답글 공유
What can it be grounded to if I don't have a metal desk and am in Europe? There is no middle screw or ground slot, at least where I live.
Pyuukin - 답글 공유
Double check your outlets, it's possible that a ground adapter plug like the following one will work for you.
Europlug example:
https://eleshop.eu/esd-earthing-plug.htm...
UK example:
https://www.vodex.co.uk/product/esd-eart...
If you don't have any grounded outlets in your home, you might consider connecting your mat to a nearby radiator (assuming that your plumbing is metal).
Alexander Jadczak - 답글 공유
How can you flatten the anti static mat?
Charley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 47
지난 7일: 152
지난 30일: 573
전체 시간: 36,024
