주요 콘텐츠로 건너뛰기
How to access the battery inside a Sony H.ear on 3
필요한 것
  1. How to access the battery inside a Sony H.ear on 3, Extend the Right Speaker: 1 단계, 이미지 2개 중 1개 How to access the battery inside a Sony H.ear on 3, Extend the Right Speaker: 1 단계, 이미지 2개 중 2개
    • Extend the Right cup and fold the Left cup away via the headband .
    • This will help protect the other ear pad while you work on this one.
  2. How to access the battery inside a Sony H.ear on 3, Unclip the Right Ear Pad: 2 단계, 이미지 3개 중 1개 How to access the battery inside a Sony H.ear on 3, Unclip the Right Ear Pad: 2 단계, 이미지 3개 중 2개 How to access the battery inside a Sony H.ear on 3, Unclip the Right Ear Pad: 2 단계, 이미지 3개 중 3개
    • The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
    • Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
    • Try not to damage or peel off the leather while doing this. It helps if you pry towards the speaker housing, not the leather cup.
    • Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
    • When re-assembling, make sure that the stitching line on the ear pad is facing the bottom.
  3. How to access the battery inside a Sony H.ear on 3, Unscrew the casing on the Right Speaker: 3 단계, 이미지 1개 중 1개
    • Check that you are on the Right Speaker using the indicator on the headband.
    • Use a JIS #000 screwdriver to remove the 5 6mm screws holding the Right Speaker casing in place.
    • Gently lift the casing apart like a book from the bottom.
    • Do not lift it completely away as the touchpad is still connected by a delicate ribbon cable.
    • When re-assembling, make sure the touchpad ribbon cable isn't pinched by the casing.
  4. How to access the battery inside a Sony H.ear on 3, Locate the battery and touchpad connectors: 5 단계, 이미지 3개 중 1개 How to access the battery inside a Sony H.ear on 3, Locate the battery and touchpad connectors: 5 단계, 이미지 3개 중 2개 How to access the battery inside a Sony H.ear on 3, Locate the battery and touchpad connectors: 5 단계, 이미지 3개 중 3개
    • Gently peel back the foam tape with a spudger and unstick it from the two cables underneath.
    • The battery and headband cable held in place against the PCB and internal enclosure of the Right Speaker with foam tape. The ZIF connector the touchpad is to the side and not covered in tape.
    • Headband cable connector (under foam tape)
    • Battery connector (under foam tape)
    • ZIF connector for touchpad
    • Foam tape
  5. 이 단계에 사용된 도구:
    • Using tweezers, gently grab and pull the smaller connector up from the circuit board to disconnect the battery.
    • Be extra careful to make sure you don't puncture the battery with the tweezers.
    • Using a spudger, gently flip up the latch on the ZIF connector on the circuit board connecting the touchpad.
    • Gently lift the ribbon cable away.
  6. How to access the battery inside a Sony H.ear on 3, Remove the Touchpad: 8 단계, 이미지 1개 중 1개
    • You can now safely remove the touchpad from the Right Speaker.
    • Now the battery should be ready to remove!
    • It seems to be stuck firmly in place. My guess is that removing it is going to be either like the WH-1000XM3 or the WH-1000XM4.
결론
작성자
1다른 기여자 명과 함께
Caius Nocturne
회원 가입일: 07/12/21
2,076 평판
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 369
