주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM3 Battery Replacement
필요한 것
    1. Sony WH-1000XM3 Battery Replacement, Release the plastic clips: 1 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Release the plastic clips: 1 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Release the plastic clips: 1 단계, 이미지 3개 중 3개
      • Before beginning any repairs, turn off your headphones.
      • The earcup cushions of the Sony WH-1000XM3 are held in place by small plastic clips and it's the same removal procedure for both, the left and the right cushion.
      • In case you want to replace the battery you're required to remove the RIGHT earcup cushion.
      • Insert a spudger into the gap between the earcup cushion and the earcup frame.
      • A screwdriver or a flat pencil will also do the job but might scratch your headphone housing or damage the cushions.
      • Pry up the earcup cushion by tilting the spudger downwards to release the plastic clips.
      • Repeat the previous step around the perimeter of the earcup cushion to release the remaining clips.
      댓글 쓰기
    2. Sony WH-1000XM3 Battery Replacement, Remove the earcup cushion: 2 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Remove the earcup cushion: 2 단계, 이미지 2개 중 2개
      • Remove the earcup cushion.
      댓글 쓰기
    1. Sony WH-1000XM3 Battery Replacement, Remove the foam liner: 3 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Remove the foam liner: 3 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Remove the foam liner: 3 단계, 이미지 3개 중 3개
      • The foam liner covering the speaker is held in place by two small pieces of mild adhesive.
      • Avoid separating the different foam layers during the following procedure.
      • Carefully peel the foam liner off the earcup frame.
      • Remove the foam liner.
      댓글 쓰기
    2. Sony WH-1000XM3 Battery Replacement, Unfasten the plastic cover screws: 4 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the four 10.4 mm-long screws securing the plastic cover of the earcup frame.
      댓글 쓰기
    3. Sony WH-1000XM3 Battery Replacement, Pry up the plastic cover: 5 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Pry up the plastic cover: 5 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Pry up the plastic cover: 5 단계, 이미지 3개 중 3개
      • Turn the headphones over.
      • Insert an opening pick into the gap between the plastic cover and the earcup frame.
      • Use the opening pick to pry up the plastic cover until you can get a good grip to it.
      • Don't try to remove the plastic cover all the way yet. The electrodes inside the cover which sense gesture controls are still connected to the headphone assembly.
      댓글 쓰기
    4. Sony WH-1000XM3 Battery Replacement, Open the earcup cover: 6 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Open the earcup cover: 6 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Open the earcup cover: 6 단계, 이미지 3개 중 3개
      • Avoid straining the gesture control cable during the following procedure.
      • Carefully fold the right earcup cover to the left like you would open the front page of a book and place it next to the earcup frame.
      댓글 쓰기
    5. Sony WH-1000XM3 Battery Replacement, Disconnect the gesture control cable: 7 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Disconnect the gesture control cable: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of blunt nose tweezers or your fingers to disconnect the gesture control ribbon cable by pulling it straight out of its socket.
      댓글 쓰기
    6. Sony WH-1000XM3 Battery Replacement, Remove the protective foam sticker: 8 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Remove the protective foam sticker: 8 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Remove the protective foam sticker: 8 단계, 이미지 3개 중 3개
      • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      • Use a pair of tweezers to carefully peel the protective foam sticker off the battery and the thermal sensor.
      댓글 쓰기
    7. Sony WH-1000XM3 Battery Replacement, Remove the protective cloth sticker: 9 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Remove the protective cloth sticker: 9 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Remove the protective cloth sticker: 9 단계, 이미지 3개 중 3개
      • Use a pair of tweezers or your fingers to carefully remove the protective cloth sticker.
      댓글 쓰기
    8. Sony WH-1000XM3 Battery Replacement, Free the battery: 10 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Free the battery: 10 단계, 이미지 2개 중 2개
      • Use a pair of tweezers to carefully bend the thermal sensor to the side to get free access to the battery.
      댓글 쓰기
    9. Sony WH-1000XM3 Battery Replacement, Free the battery cables: 11 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Free the battery cables: 11 단계, 이미지 2개 중 2개
      • The black and red battery cables are routed underneath a little plastic hook on the battery frame.
      • Use a pair of tweezers to carefully free the battery cables.
      댓글 쓰기
    10. Sony WH-1000XM3 Battery Replacement, Free the battery connector: 12 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Free the battery connector: 12 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger or an opening pick to carefully fold the cables blocking the battery connector to the side until you get free access to the connector.
      댓글 쓰기
    11. Sony WH-1000XM3 Battery Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 Sony WH-1000XM3 Battery Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
      • Use a pair of blunt nose tweezers to grasp the sides of the battery connector.
      • Pull the connector up and out of its socket, gently rocking it back and forth to loosen the clips securing it.
      • Always pull cables by their connectors and not the wires themselves.
      댓글 쓰기
    12. Sony WH-1000XM3 Battery Replacement, Insert an opening pick: 14 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Insert an opening pick: 14 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Insert an opening pick: 14 단계, 이미지 3개 중 3개
      • Insert the tip of an opening pick into the gap between the right edge of the battery and the battery housing.
      • Rotate the opening pick to insert one of its long edges into the gap.
      댓글 쓰기
    13. Sony WH-1000XM3 Battery Replacement, Pry up the battery: 15 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Pry up the battery: 15 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Pry up the battery: 15 단계, 이미지 3개 중 3개
      • Slide the opening pick underneath the battery.
      • Pry up the battery intermittently to work it away from its adhesive.
      댓글 쓰기
    14. Sony WH-1000XM3 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 1개 Sony WH-1000XM3 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 2개 Sony WH-1000XM3 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Tesa 61395 Tape
      $8.95
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • Remove old adhesive backings before installing new adhesive and clean the relevant areas with isopropyl alcohol (>90%).
      • If your replacement battery doesn't come with replacement adhesive, secure the new battery with pre-cut adhesive or double-sided adhesive tape (OEM adhesive is a 32x32 mm square). In order to position it correctly, apply the new adhesive into the device at the place where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
취소: 해당 안내서를 완성하지 않았습니다.
다른 80명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
262,857 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 58,496개를 작성함
26가이드 댓글
Thank you! This is a very detailed and helpful guide. I especially appreciated the battery calibration tip at the end of it! The battery removal was probably the most difficult part, as the adhesive was strong. Slowly working the opening pick under the battery as directed did the trick, though.
Brady Eisert - 답글 공유
Raul Roos - 답글 공유
Thank you very much. This gonna help me out. Draining the battery now and gonna give it a shot later today. I love this headphones and I didn't want to get rid of them.
vectorracer - 답글 공유
Hola. Aparte de cambiar la bateria de estos auriculares, no sabria usted donde puedo comprar para cambiarla la toma del puerto de carga de estos auriculares. Porque parece que se dañó de alguna forma. No me entra el cable , me lo hecha para atras. Tengo que apretarlo con mucha fuerza para que cargue, aun así me lo despide para atras y no carga. Gracias si pudiera ayudarme.
francisco-tiscar@hotmail.com
Francisco Garcia Pérez - 답글 공유
The batterie replacement was very easy. The guide described everything perfectly. Well done and thanks! I already tried to do the calibration once, but it seems it has not worked yet as the software gave me, for instance, 80% first and 5 minutes later it has dropped down to 30% and then very quickly to 10%. I have these 10% now for more than 8 hours. So it seems it is not calibrated. Any ideas? I also tried to reset the headphones. It not really worked.
Michael - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 48
지난 7일: 361
지난 30일: 1,573
전체 시간: 137,197
