주요 콘텐츠로 건너뛰기
How to add wireless charging to Samsung Galaxy S4 mini
필요한 것
  1. How to add wireless charging to Samsung Galaxy S4 mini, Preparing the wireless charging pad, in order to fit inside the back cover: 1 단계, 이미지 2개 중 1개 How to add wireless charging to Samsung Galaxy S4 mini, Preparing the wireless charging pad, in order to fit inside the back cover: 1 단계, 이미지 2개 중 2개
    • Disassembling the wireless charging pad, to make it as thin as possible.
    • Inside there is a rubber pad, in order to prevent excessive heat disipating through the back of the charging pad, remove this.
  2. How to add wireless charging to Samsung Galaxy S4 mini, Adding connecting wires to the wireless charging pad: 2 단계, 이미지 1개 중 1개
    • Soldering on thin flexible wires to the + and - on the wireless charging pad
  3. How to add wireless charging to Samsung Galaxy S4 mini, Gaining access to the internal USB board: 3 단계, 이미지 1개 중 1개
  4. How to add wireless charging to Samsung Galaxy S4 mini, Soldering wireless charging pad onto the USB port: 4 단계, 이미지 2개 중 1개 How to add wireless charging to Samsung Galaxy S4 mini, Soldering wireless charging pad onto the USB port: 4 단계, 이미지 2개 중 2개
    • Soldering the wireless charging pad connection + to CN2 on the USB port and - to the ground on the USB port, any part of the external metal surface should work.
  5. How to add wireless charging to Samsung Galaxy S4 mini, Altering back cover to fit the wires inside the phone: 5 단계, 이미지 1개 중 1개
    • Use a small file to make room for the wires on the back frame just below where the battery sits.
  6. How to add wireless charging to Samsung Galaxy S4 mini, Placing the back cover once more: 6 단계, 이미지 1개 중 1개
    • Using the USB board replacement guide, step 3 - 8 in reverse order to place the back cover, making sure the wires to the charging pad fits through the ready made holes.
  7. How to add wireless charging to Samsung Galaxy S4 mini, Placing wireless charging pad to keep NFC functioning: 7 단계, 이미지 1개 중 1개
    • Placing the wireless charging pad, slightly off center to keep NFC, which is implemented in the battery, working.
  8. How to add wireless charging to Samsung Galaxy S4 mini, Booting the phone to check everything is working: 8 단계, 이미지 1개 중 1개
    • Samsung Galaxy S4 mini booting after fitting wireless charging pad.
결론
While one would think, soldering a charging coil onto the charging connections would yield in a shortening of the normal connections to the battery, how ever it turns out the combination is very robust.
The phone will charge without issues on a cable connection, aswell as on the wireless charging pad, and data connection via cable remains intact.
By using the charging pad, the coil do get a bit warm, the insulation material removed in step 1, to make it as thin as possible can have an effect on the heat dissepating to the battery from the coil.
Over my usage of this setup I have not yet come across any miss behaviour of the phone due to the charging over wireless or any other issues arisen from this configuration.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kenneth H. Nielsen
회원 가입일: 08/04/11
449 평판
안내서 1개를 작성함
2가이드 댓글
I tryed to copy your guide and soldered everything in place (5V to this usb pin & Ground to the usb-port), messed up the charging coil a bit by ripping off the whole connector (I now have only 2 pads left for soldering to) and if i place it on the dock, the flashy lights on the dock will turn on, but the phone will not charge.
As you said normal charging by usb works fine, but i cant figure out my problem.
Jann Bern - 답글
Hi Jann
I have used this approach on three different phones, you need to make sure the + connection on the charging pad is soldered onto the connection on the USB port that is marked by the CN2 arrow on the main board.
I had one that showed the same issues you are describing here, taking the phone apart and resoldering the + connection solved that issue.
Best regards
Kenneth H. Nielsen -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 42
전체 시간: 18,637
