주요 콘텐츠로 건너뛰기
How to build a continuity tester from common everyday items
필요한 것
동영상 개요
  1. How to build a continuity tester from common everyday items, Disassembly: 1 단계, 이미지 3개 중 1개 How to build a continuity tester from common everyday items, Disassembly: 1 단계, 이미지 3개 중 2개 How to build a continuity tester from common everyday items, Disassembly: 1 단계, 이미지 3개 중 3개
    • Here is one of those cards that plays some annoying music once it is opened up.
    • Open the card and there will be a fold-over page that needs to be opened to get to the components. Here a long knife was used since it could not be determined how the parts underneath were oriented etc.
    • Once the glue is released from that page, fold it over to reveal the components.
  2. How to build a continuity tester from common everyday items, Introduction to function: 2 단계, 이미지 3개 중 1개 How to build a continuity tester from common everyday items, Introduction to function: 2 단계, 이미지 3개 중 2개 How to build a continuity tester from common everyday items, Introduction to function: 2 단계, 이미지 3개 중 3개
    • This musical card has two main components, The circuit board with the IC's for the music, batteries etc., and the speaker
    • There is a plastic divider that separates the contact from the circuit board. This is what turns the music off. It will turn on when pulled forward and allowing the contact to close the circuit.
    • Once the plastic divider is removed the contact will close the circuit and the music will play
  3. How to build a continuity tester from common everyday items, Construction: 3 단계, 이미지 3개 중 1개 How to build a continuity tester from common everyday items, Construction: 3 단계, 이미지 3개 중 2개 How to build a continuity tester from common everyday items, Construction: 3 단계, 이미지 3개 중 3개
    • Next we will need two electrical wires. Any length will do but should be somewhat short enough to be easily managed without becoming tangled etc.
    • Bend the contact that was previously repsonsible for closing the on/off circuit straight up. This is thin metal so it'll bend easy and will also fatigue easy, bend only one time.
    • Remove the insulation from both ends of the two wires. on one end remove about 3/8 of an inch and the other end about one inch. No exact science just make sure that the exposed wires are long enough.
  4. How to build a continuity tester from common everyday items, Construction: 4 단계, 이미지 3개 중 1개 How to build a continuity tester from common everyday items, Construction: 4 단계, 이미지 3개 중 2개 How to build a continuity tester from common everyday items, Construction: 4 단계, 이미지 3개 중 3개
    • Wrap one wire around the bend contact a couple of times and twist the end around the wire itself.
    • Place the exposed wire from the other cable on the flat contact on the circuit board.
    • Use electric tape to secure the bottom wire and to isolate and secure the wire on the other contact as well.
    • The components are adhered via some kind of tape to the card. This tape functioned as a guide to cut the whole musical part way from the greeting card.
  5. How to build a continuity tester from common everyday items, Final: 5 단계, 이미지 1개 중 1개
    • Complete Continuity Tester. Function was tested and this was a success. Now every time you check for continuity you will hear some Minions singing a happy song :-)
결론
This tool does actually work and is capable of testing continuity. Build cost was $2.99 for the card.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
837,164 평판
안내서 123개를 작성함
Global Fixers Global Fixers 회원
Community
56 회원들
안내서 422개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 28
지난 30일: 115
전체 시간: 4,454
