이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Your camera should look something like this.
Clean the marked areas with a cotton swab soaked in CLR or vinegar.
Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
