주요 콘텐츠로 건너뛰기
How to clean and reapply thermal paste on ATI Radeon X1900 XTX
필요한 것
  1. How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 1 단계, 이미지 1/2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX, How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 1 단계, 이미지 2/2
    • Start by removing the card from the PC if you haven't already.
  2. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 2 단계, 이미지 1/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 2 단계, 이미지 2/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 2 단계, 이미지 3/3
    • The fan's power cable is located towards the bottom-left of the card.
    • Disconnect the cable from the card.
    • The cable and its connector on the X1900 are fragile. Be careful, and try not to use excessive force when removing it.
  3. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 3 단계, 이미지 1/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 3 단계, 이미지 2/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 3 단계, 이미지 3/3
    • Removing the heatsink from the card:
    • The clamp is held on by four small Phillips screws. Remove them, then the clamp.
    • Remove the four phillips screws surrounding the clamp.
  4. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 4 단계, 이미지 1/1
    • Separate the heatsink and the card.
  5. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 5 단계, 이미지 1/2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 5 단계, 이미지 2/2
    • Replacing Thermal Paste:
    • Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
  6. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 6 단계, 이미지 1/2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 6 단계, 이미지 2/2
    • Removing the heatsink's plastic cover:
    • Remove these Phillips screws.
    • Seperate the plastic cover from the metal heat sink.
  7. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 7 단계, 이미지 1/2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 7 단계, 이미지 2/2
    • Cleaning dust out of the heat sink:
    • Using a cotton swab/q-tip, clean the edges of the heat sink. You can also use canned air if available.
  8. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 8 단계, 이미지 1/2 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 8 단계, 이미지 2/2
    • Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
  9. How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 9 단계, 이미지 1/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 9 단계, 이미지 2/3 How to clean and reapply thermal paste on ATI Radeon X1900 XTX: 9 단계, 이미지 3/3
    • Re-Applying Thermal Paste:
    • Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
    • For more detailed directions, follow our Applying Thermal Paste Guide.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
37,014 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 한 개
Super!!!!! j'ai suivi a la lettre; j'espère sauver ma carte; j'attends la pate thermique.
guz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 13,278
