주요 콘텐츠로 건너뛰기
How to clean the CONDOR L130I3E fan
동영상 개요
  1. How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: 1 단계, 이미지 3개 중 1개 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: 1 단계, 이미지 3개 중 2개 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: 1 단계, 이미지 3개 중 3개
    • First of all, make sure your device is switched off and unplugged.
    • Remove the battery by pulling the two screws in the direction indicated by the pins.
    • Pull the battery up.
  2. How to clean the CONDOR L130I3E fan: 2 단계, 이미지 3개 중 1개 How to clean the CONDOR L130I3E fan: 2 단계, 이미지 3개 중 2개 How to clean the CONDOR L130I3E fan: 2 단계, 이미지 3개 중 3개
    • To remove the hard drive, unplug its screws in this cover.
    • Pull the hard drive in the direction indicated to remove it.
    • Then we remove the hard drive from its place with ease.
  3. How to clean the CONDOR L130I3E fan: 3 단계, 이미지 3개 중 1개 How to clean the CONDOR L130I3E fan: 3 단계, 이미지 3개 중 2개 How to clean the CONDOR L130I3E fan: 3 단계, 이미지 3개 중 3개
    • To access the motherboard, you must first remove the keyboard because underneath it screws should be removed to separate the base of the chassis from the top of the keyboard.
    • With a flat screwdriver we remove the keyboard by pressing the red-pointed component and pushing the keyboard up to release it.
  4. How to clean the CONDOR L130I3E fan: 4 단계, 이미지 2개 중 1개 How to clean the CONDOR L130I3E fan: 4 단계, 이미지 2개 중 2개
    • Remove the keyboard connector from the motherboard
    • Keyboard is now removed successfully
  5. How to clean the CONDOR L130I3E fan: 5 단계, 이미지 3개 중 1개 How to clean the CONDOR L130I3E fan: 5 단계, 이미지 3개 중 2개 How to clean the CONDOR L130I3E fan: 5 단계, 이미지 3개 중 3개
    • Remove the top cover and remove the processor cooling fan.
    • Unscrew the screws indicated in red to remove the cooling fan.
    • Remove the fan.
  6. How to clean the CONDOR L130I3E fan: 6 단계, 이미지 1개 중 1개
    • We now clean and remove the dust and sediments that hinder fan function and increase processor heat.
결론
다른 7명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
AMOUR nasreddine
회원 가입일: 11/20/17
1,179 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 13
전체 시간: 1,190
