주요 콘텐츠로 건너뛰기
How to factory reset Polycom 335 IP Phone
    • 1. Hold 1+7+3+5 while powering on the device. This will prompt you for a Reset Password.
    • 2. By default the password is 456. You can reset the password with the Mac Address on the back. This is where it can be confusing. 1->Aa is used for entering the normal numbers. A->a1 is used for entering letters.
    • For the letter C we would hit the character button and change it to A->a1 then press the number 2 three times because 2 is actually A, B and C.
    • 3. Now that the unit had reset configuration and rebooted select Setup. The New default password is 456.
    • Navigate through the menu and find Reset to Defaults. Select and reboot. Log back into unit and verify all IP addresses and other client Information has been successfully removed.
결승점
Goulithum
회원 가입일: 01/09/15
1,534 평판
안내서 2개 작성하였습니다
Sage Electronics Sage Electronics 회원
Business
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 82
전체 시간: 17,248
