주요 콘텐츠로 건너뛰기
How to make real espresso
  1. How to make real espresso, Preparation of the portafilter machine: 1 단계, 이미지 3개 중 1개 How to make real espresso, Preparation of the portafilter machine: 1 단계, 이미지 3개 중 2개 How to make real espresso, Preparation of the portafilter machine: 1 단계, 이미지 3개 중 3개
    • Before proceeding to the actual pleasure of brewing coffee, you need to make sure that the machine is hot enough and thus reaches operating temperature (116-117 degrees). This can be seen from three parameters:
    • 1) the temperature under the drip tray for the residual water.
    • 2) on the left, the pressure indicator for the steam (in German: Milchaufschäumer)
    • 3) on the right at the pressure indicator for the brewing rotor.
    • Normally, the portafilter heats up to operating temperature within 15-20 minutes.
    • After the operating temperature (116-117 degrees) has been reached, you should quickly follow two additional steps
    • Repeat the process 2-3 times
  2. How to make real espresso, Selection of portafilter and preparation: 2 단계, 이미지 3개 중 1개 How to make real espresso, Selection of portafilter and preparation: 2 단계, 이미지 3개 중 2개 How to make real espresso, Selection of portafilter and preparation: 2 단계, 이미지 3개 중 3개
    • For a delicious espresso, or for a good cappuccino base, it is always recommended to use a portafilter with single spout. For a Lungo/Americano (extended espresso) or if you want to brew coffee for 2 people, you can also use the double spout.
    • Please note: Whether you use the single spout or double spout, the portafilter must always be dry and clean for best results.
    • For the grinder, make the lower left selection, here everything is set optimally for a delicious cup of espresso.
    • Put on the sieve and let the time run completely into the carrier. This should be about 9 seconds. You can also stop earlier if you don't want it to be so short and strong. :-) To do this, just give the portafilter a quick double tap on the little "button" on the grinder.
  3. How to make real espresso, Tamp and co.: 3 단계, 이미지 3개 중 1개 How to make real espresso, Tamp and co.: 3 단계, 이미지 3개 중 2개 How to make real espresso, Tamp and co.: 3 단계, 이미지 3개 중 3개
    • Important: When brewing coffee from a portafilter, the coffee must always be pressed hard enough into the portafilter. Or in technical jargon also called " to tamp".
    • Place the portafilter with the ground coffee on a non-slip surface.
    • With the temper then use pressure to tamp down the coffee grounds evenly (as shown in the 2nd picture).
    • After tamping, it should look like in the 3rd picture.
  4. How to make real espresso, Inserting the portafilter and brewing: 4 단계, 이미지 3개 중 1개 How to make real espresso, Inserting the portafilter and brewing: 4 단계, 이미지 3개 중 2개 How to make real espresso, Inserting the portafilter and brewing: 4 단계, 이미지 3개 중 3개
    • After tamping, please insert the portafilter carefully into the holder and adjust it with a slight pressure. This should then look like the first picture of step 1.
    • Place your favorite cup or glass underneath ;-)
    • Place the reference lever upwards. If the previous steps have all been done as instructed in the guide, the machine should take about 5-6 seconds to properly start the brewing process. In barista jargon, this is called CODA DI TOPO (Italian for "mouse tail"). :-)
    • As explained in the steps before, the machine has a timer, you should definitely keep an eye on it during the process. The optimum brewing time is 20-30 seconds. Then slowly lower the reference lever again.
  5. How to make real espresso, Cleaning the machine and the pleasure afterwards: 5 단계, 이미지 1개 중 1개
    • Now we have reached the last step, the espresso is brewed and smells delicious. A thick, oily crema should be visible on the cup or in the glass.
    • To continue excellent taste and cleanliness, it is very important to clean everything afterwards.
    • Knock out the brew group at the drip tray under the grinder and rinse with warm water.
    • Confirm the reference lever and let the coffee that has stuck run out into the water tank
    • Adjust the portafilter back into the device, press the reference lever again and run it through again with hot water.
결론
I hope you now enjoy your delicious espresso. If you repeat the whole process a few times, you'll get into a routine.
And very important, always remember to keep the machine and the portafilter scrupulously clean. :-)
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Maurizio Luciano
회원 가입일: 04/01/22
151 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 28
전체 시간: 726
