주요 콘텐츠로 건너뛰기
How to open and clean Keurig Coffee Maker
필요한 것
  1. How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: 1 단계, 이미지 3개 중 1개 How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: 1 단계, 이미지 3개 중 2개 How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: 1 단계, 이미지 3개 중 3개
    • Keurig K40 not brewing/dispensing 12oz
    • Open the Keurig all the way to remove the K-cup Holder
    • The K-cup holder simply pulls straight up. There might be a bit of resistance from some spring clips. The flaky debris is actually coffee from reusable K-cup filters.
  2. How to open and clean Keurig Coffee Maker: 2 단계, 이미지 3개 중 1개 How to open and clean Keurig Coffee Maker: 2 단계, 이미지 3개 중 2개 How to open and clean Keurig Coffee Maker: 2 단계, 이미지 3개 중 3개
    • K-cup insert removed. Clean with hot water as needed.
    • On the bottom of the K-cup insert is a tapered needle that punctures the bottom of the K-cup. On the side of it is a small hole. Use a paper clip (or similar) and insert it in there to remove any scale, coffee grounds etc.
    • Next is to clean the top needle. It is trickier since it is somewhat hard to reach around the sides of the needle. There will be three holes around the needle. Open the Keurig all the way, and again use a paper clip (or similar).
  3. How to open and clean Keurig Coffee Maker: 3 단계, 이미지 3개 중 1개 How to open and clean Keurig Coffee Maker: 3 단계, 이미지 3개 중 2개 How to open and clean Keurig Coffee Maker: 3 단계, 이미지 3개 중 3개
    • A hypodermic needle or similar can also be used to open up the water outlet
    • Next remove the water tank by simply lifting it up.
    • On the inside bottom of the tank is a simple check valve that allows the removal of the tank, then empty the tank.
  4. How to open and clean Keurig Coffee Maker: 4 단계, 이미지 3개 중 1개 How to open and clean Keurig Coffee Maker: 4 단계, 이미지 3개 중 2개 How to open and clean Keurig Coffee Maker: 4 단계, 이미지 3개 중 3개
    • Top part of the check valve on the bottom. there is a fine screen that acts as a filter. Remove that by removing the three Phillips screws with a long #2 Phillips screwdriver. Clean the screen under running water with a brush. Reassemble after proper cleaning.
    • Next step is to remove the top cover to get to the water supply to the K-cup. Open the Keurig. remove two Phillips screws that hold it in place.
    • Lift the top cover up and forward to remove it.
  5. How to open and clean Keurig Coffee Maker: 5 단계, 이미지 3개 중 1개 How to open and clean Keurig Coffee Maker: 5 단계, 이미지 3개 중 2개 How to open and clean Keurig Coffee Maker: 5 단계, 이미지 3개 중 3개
    • Water supply from the boiler to the K-cup needle is via a water hose through a check valve.
    • Remove the two small screws that hold the water line to the inlet
    • Unhook the water line from the connector above the K-cup needle. it is a simple press fit.
    • Next remove the tie straps. (You don't have to do this step) Just remove the other end of hose from pump. You might have to use a flat head screwdriver to lift up on end of hose while pulling up
  6. How to open and clean Keurig Coffee Maker: 6 단계, 이미지 1개 중 1개
    • Test the check valve. Blowing air in it from the boiler side should cause it to open. Repeat that a couple of times to loosen any sediments etc. It will also help to run some hot water from the K-cup side into the check valve and shake it up. Once it is cleaned, replace the check valve and the tie straps. Reassemble the Keurig
결론
다른 111명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
836,034 평판
안내서 123개를 작성함
93가이드 댓글
Perfect - been looking all over for a solution besides trashing the unit.
Thank you for the step by step instructions!
kellywihlm - 답글
Awesome! didn't want to have to buy a new Keurig - worked like a charm!
cabate - 답글
awesome thank you kindley
racinnut2001 - 답글
Outstanding presentation. I've had my Keurig apart before. However, as I use well water and don't have the best filtration system, mine tends to clog frequently.
I will add however, that the case for, at least some Keurig coffee makers have clips holding the cover in place that can be rather difficult to release.
Bill Leach - 답글
I should add, excellent photography!
Bill Leach - 답글
댓글 쓰기
조회 통계:
지난 24시간: 33
지난 7일: 363
지난 30일: 2,138
전체 시간: 640,760
