주요 콘텐츠로 건너뛰기
How to repair a trouser/cuff hem (by shortening)
필요한 것
  1. How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 3/3
    • Identify the defective area and assess how large the damage is.
  2. How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 3/3
    • Use a "seam ripper" tool to unstitch the original hem.
    • Unfold the hem.
    • Draw line above the defective part that you want to remove.
  3. How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 3/3
    • Cut along the line and set the removed piece aside.
    • Turn the item inside-out.
  4. How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 3/3
    • Draw a 1st line 2 cm from the edge - and a 2nd line with 2cm on top of it.
    • Fold the new hem twice on those lines.
  5. How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 3/3
    • Set up the iron on moderate heat without stream
    • Fixed the folded hem by ironing and then with pins.
  6. How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 3/3
    • Use a sewing machine to fix the hem.
    • Stitch 2mm from the edge and add a locking stitch at both ends.
    • Stitch the 2nd line parallel with the first.
    • Cut the extra thread to make a clean finished seam. Turn the item right-way-round.
  7. How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 1/3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 2/3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 3/3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
회원 가입일: 07/19/23
5,208 평판
안내서 46개 작성하였습니다
INTERSPORT INTERSPORT 회원
Community
16 회원들
안내서 48개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 45
