주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to repair a trouser/cuff hem (without shortening)
필요한 것
  1. How to repair a trouser/cuff hem (without shortening), Identify the defect: 1 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (without shortening), Identify the defect: 1 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (without shortening), Identify the defect: 1 단계, 이미지 3개 중 3개
    • Identify the defective area and assess how large the damage is.
    댓글 쓰기
  2. How to repair a trouser/cuff hem (without shortening), Prepare the stitching: 2 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (without shortening), Prepare the stitching: 2 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (without shortening), Prepare the stitching: 2 단계, 이미지 3개 중 3개
    • Cut away any damaged thread around the hole, to create a clean surface to repair.
    • Take care: don't cut away fabric, as this will shorten the repair.
    • Turn the edges of the hole inside, so that they are tucked inside the hole.
    댓글 쓰기
  3. How to repair a trouser/cuff hem (without shortening), Sew the repair: 3 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (without shortening), Sew the repair: 3 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (without shortening), Sew the repair: 3 단계, 이미지 3개 중 3개
    • Pin the folded parts of the hole securely in place.
    • Prepare the sewing machine and offer up the repaired area.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Depress the sewing machine foot and remove any pins in the way of the sewing route. Start sewing a straight line from one side of the hole to the other, close to the edge of the hem, and add a lock stitch at the beginning and end.
    댓글 쓰기
  4. How to repair a trouser/cuff hem (without shortening), Finished and ready!: 4 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (without shortening), Finished and ready!: 4 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (without shortening), Finished and ready!: 4 단계, 이미지 3개 중 3개
    • Finish the sewing and cut the loose thread to make a neat finish.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    댓글 쓰기
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 68개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 172개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 89
전체 시간: 1,687
