주요 콘텐츠로 건너뛰기
How to repair a trouser/cuff hem (by shortening)
필요한 것
  1. How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Defective hem: 1 단계, 이미지 3개 중 3개
    • Identify the defective area and assess how large the damage is.
  2. How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 2 단계, 이미지 3개 중 3개
    • Use a "seam ripper" tool to unstitch the original hem.
    • Unfold the hem.
    • Draw line above the defective part that you want to remove.
  3. How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 3 단계, 이미지 3개 중 3개
    • Cut along the line and set the removed piece aside.
    • Turn the item inside-out.
  4. How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 4 단계, 이미지 3개 중 3개
    • Draw a 1st line 2 cm from the edge - and a 2nd line with 2cm on top of it.
    • Fold the new hem twice on those lines.
  5. How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 5 단계, 이미지 3개 중 3개
    • Set up the iron on moderate heat without stream
    • Fixed the folded hem by ironing and then with pins.
  6. How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 6 단계, 이미지 3개 중 3개
    • Use a sewing machine to fix the hem.
    • Stitch 2mm from the edge and add a locking stitch at both ends.
    • Stitch the 2nd line parallel with the first.
    • Cut the extra thread to make a clean finished seam. Turn the item right-way-round.
  7. How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 3개 중 1개 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 3개 중 2개 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 7 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 26
전체 시간: 393
