주요 콘텐츠로 건너뛰기
How to shorten shirt straps
필요한 것
  1. How to shorten shirt straps, How to shorten shirt straps: 1 단계, 이미지 3개 중 1개 How to shorten shirt straps, How to shorten shirt straps: 1 단계, 이미지 3개 중 2개 How to shorten shirt straps, How to shorten shirt straps: 1 단계, 이미지 3개 중 3개
    • Put on the shirt.
    • Pull the strap up until you reach your new desired length. Be sure to take the same amount of fabric from the front and the back of the seam.
    • Pin both straps to the desired length.
  2. How to shorten shirt straps: 2 단계, 이미지 2개 중 1개 How to shorten shirt straps: 2 단계, 이미지 2개 중 2개
    • Remove the shirt.
    • Be careful of the pins when taking off the shirt.
    • Measure and take a note of the length. Make sure it is the same on both straps.
    • This length will be the amount your strap that will be removed.
  3. How to shorten shirt straps: 3 단계, 이미지 3개 중 1개 How to shorten shirt straps: 3 단계, 이미지 3개 중 2개 How to shorten shirt straps: 3 단계, 이미지 3개 중 3개
    • Remove the pins and flip the shirt inside out.
    • Re-pin both shirt straps. Make sure the pins follow the measurements you just took.
    • Make sure you have a clear line to sew along.
    • Check and make sure the base of the straps are lined up for a continuous edge on your shirt.
  4. How to shorten shirt straps: 4 단계, 이미지 3개 중 1개 How to shorten shirt straps: 4 단계, 이미지 3개 중 2개 How to shorten shirt straps: 4 단계, 이미지 3개 중 3개
    • Thread the sewing machine and set it to your desired stitch length.
    • Refer to your specific sewing machine manual for more guidance.
    • Align the pinned part of the shirt with the needle.
    • Put down the presser foot.
  5. How to shorten shirt straps: 5 단계, 이미지 2개 중 1개 How to shorten shirt straps: 5 단계, 이미지 2개 중 2개
    • Sew along the line mapped out by your pins.
    • Pull out the pins as you sew. Make sure not to sew over any of them.
    • If you sew over the pins, you may break the needle.
    • Make sure to backstitch at each end of the seam.
    • Repeat this step for each strap.
  6. How to shorten shirt straps: 6 단계, 이미지 1개 중 1개
    • Put the shirt back on.
    • Confirm the new length that you chose for the garment.
    • If the straps are too still long or short, carefully rip out your new seam and return to Step 1.
  7. How to shorten shirt straps: 7 단계, 이미지 3개 중 1개 How to shorten shirt straps: 7 단계, 이미지 3개 중 2개 How to shorten shirt straps: 7 단계, 이미지 3개 중 3개
    • Cut excess fabric from the new seams, leaving ¼ inch to ½ inch.
    • Iron the seam allowance left after your cut to the back of the shirt.
  8. How to shorten shirt straps: 8 단계, 이미지 1개 중 1개
    • Flip the shirt right side out.
    • Make a straight stitch approximately 1/8 inch behind the new shoulder seam on the outside edge.
    • Make sure your new seam properly secures the seam allowance underneath.
  9. How to shorten shirt straps: 9 단계, 이미지 1개 중 1개
    • Cut any loose threads on the shirt.
결론
Your shirt straps now should be secured at their new length.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Natalie Clark
회원 가입일: 09/29/15
227 평판
안내서 1개를 작성함
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015 회원
CPSU-GREEN-F15S15G2
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 37
전체 시간: 11,647
