소개
Whether you want to jailbreak or update your iPhone or simple because there is no other solution, Apple offers an answer to your problems: DFU mode (short for Device Firmware Update).
However, the iPhone 7 doesn’t have a physical home button. This makes that the ‘traditional’ way of putting your iPhone in DFU mode doesn’t work for this iPhone. Don’t panic yet! As always, Apple offers a solution. An easy one, it seems. Because the only thing you have to learn is a new combination of buttons. The rest of the procedure is similar to how you put older iPhones in DFU mode.
Connect your iPhone 7 to a computer or laptop with the lightning to USB cable.
After the 10 seconds, release the sleep/wake button, but continue to hold the volume down button for another 10 seconds. Pay attention! Unlike recovery mode where you get to see the message ‘Connected to iTunes’, the screen will remain black in DFU mode.
If you do see the connected to iTunes message, this means going to DFU mode has failed, and you have to start over from step 1.
The next step is to get your iPhone 7 out of DFU mode. As long as your iPhone works fine, this should not be a problem. The only thing you have to do is:
Push the sleep/wake button and the volume down button at the same time until the Apple logo appears. Your iPhone should automatically go to the lock screen.
Have you tried everything, but your iPhone 7 still doesn’t work properly? Then, it is likely not a software problem, which means a repair is the only solution.
다른 7명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
