주요 콘텐츠로 건너뛰기
Huawei Honor 5X Volume and Power Buttons Replacement
필요한 것
  1. Huawei Honor 5X Volume and Power Buttons Replacement, HUAWEI HONOR 5X Disassembly: 1 단계, 이미지 1개 중 1개
    • Turn off your cell phone before disassembling.
  2. Huawei Honor 5X Volume and Power Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. Huawei Honor 5X Volume and Power Buttons Replacement: 3 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. Huawei Honor 5X Volume and Power Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. Huawei Honor 5X Volume and Power Buttons Replacement: 5 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Pry off the back with a plastic opening tool.
  6. Huawei Honor 5X Volume and Power Buttons Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • Remove the pink sticker.
  7. Huawei Honor 5X Volume and Power Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three 1.5mm Phillips #000 screws.
  8. Huawei Honor 5X Volume and Power Buttons Replacement: 8 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. Huawei Honor 5X Volume and Power Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the battery from the phone.
  10. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  11. Huawei Honor 5X Volume and Power Buttons Replacement: 11 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  12. Huawei Honor 5X Volume and Power Buttons Replacement: 12 단계, 이미지 3개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement: 12 단계, 이미지 3개 중 2개 Huawei Honor 5X Volume and Power Buttons Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the motherboard.
  13. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: 13 단계, 이미지 2개 중 1개 Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to pull the button assembly from the small black clips on the back plate of the phone.
결론
작성자
6다른 기여자 명과 함께
Eric Petrous
회원 가입일: 09/03/19
145 평판
안내서 2개를 작성함
IUPUI, Team S1-G4, Hovde Fall 2019 IUPUI, Team S1-G4, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G4
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 29
전체 시간: 1,379
