주요 콘텐츠로 건너뛰기
Huawei Honor 8 Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Huawei Honor 8 Screen Replacement, Remove the back casing: 1 단계, 이미지 1/3 Huawei Honor 8 Screen Replacement, Remove the back casing: 1 단계, 이미지 2/3 Huawei Honor 8 Screen Replacement, Remove the back casing: 1 단계, 이미지 3/3
    • Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun.
    • Attention: The sides have to be hot, not scalding.
    • Insert the iSesamo delicatley between the two sides (see photo)
    • Once the iSesamo is inserted, slide it along the sides to remove the adhesive.
    • ATTENTION: DO NOT SLIDE THE ISESEMO ALONG THE PART MARKED IN GREEN.
  2. Huawei Honor 8 Screen Replacement, Disconnect the rear window: 2 단계, 이미지 1/2 Huawei Honor 8 Screen Replacement, Disconnect the rear window: 2 단계, 이미지 2/2
    • Remove the screw on the metal plate which protects the fingerprint sensor cable
    • Remove the the fingerprint censor cable using a plastic spudger.
  3. Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: 3 단계, 이미지 1/3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: 3 단계, 이미지 2/3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: 3 단계, 이미지 3/3
    • Remove the 16 screws with a Phillips screwdriver.
    • Using the iSesamo, remove the protection from the motherboard
  4. Huawei Honor 8 Screen Replacement, Take off the battery: 4 단계, 이미지 1/3 Huawei Honor 8 Screen Replacement, Take off the battery: 4 단계, 이미지 2/3 Huawei Honor 8 Screen Replacement, Take off the battery: 4 단계, 이미지 3/3
    • Remove the 2 tabs marked in red.
    • Gently remove the battery with a playing card or bank card.
  5. Huawei Honor 8 Screen Replacement, Prepare to take off the screen: 5 단계, 이미지 1/2 Huawei Honor 8 Screen Replacement, Prepare to take off the screen: 5 단계, 이미지 2/2
    • Peel off the connector on the screen.
    • Heat the contours of the screen as shown in Step 1.
  6. Huawei Honor 8 Screen Replacement, Take off the screen: 6 단계, 이미지 1/2 Huawei Honor 8 Screen Replacement, Take off the screen: 6 단계, 이미지 2/2
    • insert the iSesamo between the screen and the chassis
    • Be sure to pass the iSesamo under the white plate of the screen (see photo)
    • Go around the phone.
    • Note that the operation can be more complicated depending on the level of the screen.
  7. Huawei Honor 8 Screen Replacement, Clean the frame: 7 단계, 이미지 1/2 Huawei Honor 8 Screen Replacement, Clean the frame: 7 단계, 이미지 2/2
    • Carefully remove the pieces of glass and the adhesive on the frame
    • Glue the screen on the frame by passing the sheet through the hole provided for this purpose
결론
To reassemble your device, follow the instructions in reverse order :)
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Nihoul Victor
회원 가입일: 04/23/17
261 평판
안내서 1개 작성함
댓글 4개
Est-ce que quelqu'un a essayer ? a combien estimez vous la réparation: ecran + accessoires ? Car le lien ne fonctionne pas. En tout cas tuto très bien réalisé ;)
fabien6-8ol - 답글
Moi forcement ...
Chez moi le lien fonctionne, la pièce est à 55,99€, tu peux demander des accessoires gratuit
Nihoul Victor - 답글
Bonjour
Merci pour ce tuto. J'aurais juste une question.
Comment recollé la vitre arrière après la réparation ?
J'ai déjà eu le cas sur un smartphone Sony et je n'ai pas réussi à correctement recollé la face arrière.
Merci a bientôt
Comoretto Quentin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 5,244
