주요 콘텐츠로 건너뛰기
Huawei M750 Charging Port Replacement
필요한 것
  1. Huawei M750 Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Charging Port Replacement, Back Panel: 3 단계, 이미지 1/1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Charging Port Replacement: 4 단계, 이미지 1/2 Huawei M750 Charging Port Replacement: 4 단계, 이미지 2/2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Charging Port Replacement: 5 단계, 이미지 1/2 Huawei M750 Charging Port Replacement: 5 단계, 이미지 2/2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  6. Huawei M750 Charging Port Replacement, Charging Port: 6 단계, 이미지 1/2 Huawei M750 Charging Port Replacement, Charging Port: 6 단계, 이미지 2/2
    • Using the opening tool, start prying out the motherboard from the front panel along the border.
    • When the motherboard seems separated from the front panel, pull it outwards.
  7. Huawei M750 Charging Port Replacement: 7 단계, 이미지 1/2 Huawei M750 Charging Port Replacement: 7 단계, 이미지 2/2
    • The charging port is soldered to the motherboard, use this guide to do the replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kshitiz Thapa
회원 가입일: 02/11/18
389 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 249
