소개
This guide shows you how to replace the lithium-ion-battery of your Mate 10 lite.
You have to take appropriate security measures if the battery is swollen. For your own security you should drain the battery to 25% as that reduces the risk of fire if you damage the battery during repair.
The backcover is not glued so it can be opened easily.
필요한 것
Remove the SIM card by using a paperclip or a special tool and inserting it into the hole next to the SIM card tray until it pops out.
Remove the Torx T2 screws on the bottom of the case(next to the USB port)
Use the Opening tool on the bottom of the case and pry it open
go around the side to open the phone
place the device screen down and take the backcover off to the left side
Red: Phillips #00 screws
Blue: Remove the cable clamps with the Spudger
Remove the cables connecting to the backside and remove the cables that run over the battery
Insert the plastic card into the side and push them under the battery
the glue under the battery can be removed with highgrade IPA or a special glue remover. Otherwise you can pry the battery out with the spudger, the plastic cards and the opening picks
Follow the guide in the opposite direction and use the replacement battery.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
Achtung: Ich habe irrtümlich das Display "zerlegt", weil der aufgeblähte Akku hier einen Spalt gemacht hat, in den ich leider das Tool angesetzt habe... :/
