주요 콘텐츠로 건너뛰기
Huawei P20 Pro Rear Camera Lens Replacement
  1. Huawei P20 Pro Rear Camera Lens Replacement, Rear Camera Lens: 1 단계, 이미지 1개 중 1개
    • Start by placing your phone screen down on a clean, well-lit surface.
    • Wear safety glasses/goggles to protect your eyes from glass shards. This is very important.
  2. Huawei P20 Pro Rear Camera Lens Replacement: 2 단계, 이미지 2개 중 1개 Huawei P20 Pro Rear Camera Lens Replacement: 2 단계, 이미지 2개 중 2개
    • Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal.
    • A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
  3. Huawei P20 Pro Rear Camera Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • If not available, place double-sided adhesive strips in the gaps between the cameras.
    • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
  4. Huawei P20 Pro Rear Camera Lens Replacement: 4 단계, 이미지 1개 중 1개
    • All done! You can take pictures again like you were able to do before.
결론
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
다른 20명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
cPix
회원 가입일: 06/14/16
4,194 평판
안내서 8개를 작성함
2가이드 댓글
Tuto très bien expliquer je vais pouvoir maintenant reprendre de belles photos grâce à vous. Merci
Ace Ace - 답글
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
256 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 73
전체 시간: 59,922
