소개
Use this guide to replace the earpiece speaker of your Huawei P8 Lite.
필요한 것
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Bonjour, sur le mien, il y a deux fils de cuivre très très fin, souder sur le haut parleur interne…
