주요 콘텐츠로 건너뛰기
Huawei P8 Lite Earpiece Speaker Replacement
필요한 것
  1. Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: 1 단계, 이미지 1/2 Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Earpiece Speaker Replacement: 2 단계, 이미지 1/1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Earpiece Speaker Replacement: 3 단계, 이미지 1/2 Huawei P8 Lite Earpiece Speaker Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: 4 단계, 이미지 1/2 Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to grip the earpiece speaker and lift the earpiece speaker from phone.
결론
To reassemble your device, follow Teardown Guide steps 12, 6, 5, 4, 3, 2, 1 in that order.
Brayden Mann
회원 가입일: 02/05/16
639 평판
안내서 4개 작성하였습니다
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 회원
MSU-CARPENTER-S16S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 2,192
