주요 콘텐츠로 건너뛰기
Huawei P8 Lite Motherboard Replacement
필요한 것
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Brayden Mann
회원 가입일: 02/05/16
645 평판
안내서 4개를 작성함
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 회원
MSU-CARPENTER-S16S1G2
3 회원들
안내서 8개를 작성함
댓글 4개
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - 답글
mine also need a new mother
anywr l can get it asap
blessed - 답글
Hey
I need p8 lite motherboard
goitsemodimo - 답글
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 19
전체 시간: 8,212
