주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P9 Battery Replacement
필요한 것
  1. Huawei P9 Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Huawei P9 Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Huawei P9 Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Battery Replacement: 2 단계, 이미지 2개 중 1개 Huawei P9 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Battery Replacement, Fingerprint sensor: 3 단계, 이미지 2개 중 1개 Huawei P9 Battery Replacement, Fingerprint sensor: 3 단계, 이미지 2개 중 2개
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Huawei P9 Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Huawei P9 Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Unplug the antenna cable.
    • Remove the sticker that sits on top of the screw.
  5. Huawei P9 Battery Replacement: 5 단계, 이미지 3개 중 1개 Huawei P9 Battery Replacement: 5 단계, 이미지 3개 중 2개 Huawei P9 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two Phillips #00 screws that hold the metal plate in place.
    • The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
  6. Huawei P9 Battery Replacement: 6 단계, 이미지 2개 중 1개 Huawei P9 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Now you can unplug the battery connector and bend it aside.
    • The EVA-L09 model has an NFC antenna adhered onto the battery.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Mark its place on the battery with a felt pen for reassembly. Carefully peel it off and make sure not to rip or crease the antenna.
    • For reassembly, place the NFC antenna on the battery where it was before so its contacts align with their counterparts.
  7. Huawei P9 Battery Replacement: 7 단계, 이미지 2개 중 1개 Huawei P9 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Free the ends of the adhesive pull tabs to get a good grip on them.
  8. Huawei P9 Battery Replacement: 8 단계, 이미지 3개 중 1개 Huawei P9 Battery Replacement: 8 단계, 이미지 3개 중 2개 Huawei P9 Battery Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $8.95
    • The battery is secured with three pieces of adhesive, a removable pull-tab in the center, and on the SIM tray side. A third piece of adhesive on the button side has no pull-tab.
    • Pull the adhesive tabs in a slow constant movement to free the battery.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
    • There are two cables running directly underneath the battery. Take care not to damage them when prying with a spudger! You can see their position in the last picture.
    • Slowly lift the battery toward the button side and free it from the remaining hidden piece of adhesive.
    • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
결론
다른 93명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
131,064 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
29가이드 댓글
Just FYI, My replacement battery from Huawei doesn’t fit. The cable doesn’t reach the connector. Soldering Required!
https://imgur.com/gallery/vTsX8
dallebull - 답글 공유
Bonjour j es effectué cette opération.J es changé le connecteur de chargeur complet suite à un dysfonctionnement. Et la batterie aussi.Et mon soucis reste le même. Le téléphone s allumé mais pas de voyant de charge.merci de me renseigner.
Berhault - 답글 공유
Bonjour,
J’ai le même problème , avez-vous trouvé une solution ?
Amenis - 공유
J'ai le même problème quand je charge sa passe mais le pourcentage n'augmente pas
300elmoise - 공유
Bonjour suite à une panne avec mon huawei p9 j es changé le connecteur de chargeur et la batterie et mon problèmereste toujours le même. Il charge toujours pas.merci de me
Berhault - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 57
지난 30일: 280
전체 시간: 130,402
