소개
Use this guide to replace the old battery in your Huawei P9 Lite.
필요한 것
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
On the bottom of the phone remove the following screws:
Three 2.9 mm Phillips #00 screws
Four 3.8 mm Phillips #00 screws
Now you can grab the loudspeaker unit and take it out.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99
Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
다른 86명이 해당 안내서를 완성하였습니다.
댓글 24개
There is an extra step where you need to remove the cover of the board at the top of the phone in order to remove the NFC antenna which is not described in this guide. Better watch this https://www.youtube.com/watch?v=ADZiL7JK...
Thanks Costas for the hint. We added the missing step.
Cercando di rimouorere l'adesivo dell'nfc si è rotto, posso assembrale il telefono senza nfc, ovviamente invalidando questa funzione?
Si, hai ragione: si può riassemblare il telefono senza l’antenna NFC perdendo questa funzione…
