소개
Use this guide to replace the front camera in your Huawei P9 Lite.
필요한 것
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Disconnect the front camera flex from the motherboard.
Flip the motherboard over and thread the flex cable through the opening and take the camera away.
다른 5명이 해당 안내서를 완성하였습니다.
