소개
Use this guide to replace the front camera in your Huawei P9 Lite.
도구
부품
지정된 부품이 없습니다.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Disconnect the front camera flex from the motherboard.
Flip the motherboard over and thread the flex cable through the opening and take the camera away.
다른 5명이 해당 안내서를 완성하였습니다.
