이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Disconnect the motherboard flex, the battery flex and the antenna cable.
Use a spudger to lift the motherboard carefully.
Remove the motherboard assembly.
다른 9명이 해당 안내서를 완성하였습니다.
