소개
An IBM ThinkPad T42 Wi-Fi card allows the device to connect to a wireless network. If your Wi-Fi card is broken or needs to be replaced, this guide will show you how.
필요한 것
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
The only screws that need to be removed are the ones that are numbered 1-4 on the bottom of the case. Best to remove the screws with #4 next to them, then remove the keyboard and then remove 1-3 and then the palm rest. Removing the ones on the rear is unnecessary.
John Casey - 답글
