주요 콘텐츠로 건너뛰기
IBM ThinkPad X41 Battery Replacement
  1. IBM ThinkPad X41 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn laptop over, make sure lid side is faced down.
  2. IBM ThinkPad X41 Battery Replacement: 2 단계, 이미지 1/1
    • Locate battery release button lock on laptop, and press down.
  3. IBM ThinkPad X41 Battery Replacement: 3 단계, 이미지 1/1
    • Hold laptop battery release button and gently pull battery away from laptop.
결론
Magaly Espinoza
회원 가입일: 09/12/16
183 평판
안내서 1개 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 2개
How can you open the battery case and replace the lithium ion cells?
Janie Godfrey - 답글
This could be possible, but it's the hard way.
Open the battery case will be difficult, and you well need to keep the BMS circuit board inside the battery pack then build a battery pack with new cells and reactivate the BMS again as some battery BMS have a security that cut the power output when the BMS has stopped to be powered. So after replacing the cells, the battery might not work as is as the BMS might cut the power output of the battery pack.
I don't know if this battery pack has this kind of security on it's BMS.
Brendan -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 978
